3CX Attended Transfer With Gigaset
Discussion in 'Windows' started by Prionetsupport, Apr 1, 2014.
  1. Prionetsupport
    Feb 6, 2014
    7
    Hi Everybody,
    We have a situation with attended tranfer from a Gigaset E49 in combination with a N510 Base station.
    The following is happening when I make an attended tranfer from a E49 handset to another extension in the 3cx.
    Extension 100 is calling 200 (gigaset)
    The Gigaset makes an attended transfer using the R key to extension 300.
    When the tranfer is completed, after 30 seconds Extension 200 gets a recall.
    When I pick up the recall, there is no sound, in fact, the attended tranfer is completed and keeps alive.
    When I hang up the recall nothing happens, and the attended transfer between 100 and 300 is still alive.
    If you need some more information please let me know.
    11,123
    330
    A couple of things you might try...
    In 3CX under each extensions settings/Options/Extension Capabilities, there are two check boxes (by default they are checked). They are, Supports Re-invite, and Support 'Replaces' header, you can try un-checking those to see if it makes a difference.
