3CX Audio Conferences
Discussion in '3CX Phone System - General' started by Saqqara, Sep 19, 2017.
  1. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,252
    203
    On audio conferences, can you have two conferences running at the same time with totally difference attendees
    For example
    Internal User A - has a conference with Person B, Person C
    Internal User B - has a conference with Person D, Person E
    Both conferences running at the same time,
  2. IoannisM_3CX
    IoannisM_3CX Support Team
    Aug 10, 2017
    229
    18
    Hello @Saqqara
    At first you say that the attendees are totally different but in your example User B is member in both of the conferences.
    If your question is if it is possible to have simultaneous conferences then the answer is yes.
    If you meant that you want simultaneous conferences where user B participates in both, then this could also be done but User B wont be able to talk to both lines at the same time.
    Thank you
  3. Saqqara
    Mar 12, 2014
    1,252
    203
    Thanks for the info,
    My mistake user B, would only be in one conference
  4. IoannisM_3CX
    Aug 10, 2017
    229
    18
    Yes,either of the scenarios, this is something that will work like a charm.
    Thank you
