3CX Australia PSTN Gateway
Discussion in '3CX Phone System - General' started by adetterer, Jan 27, 2009.
  1. adetterer
    Aug 28, 2007
    22
    I am in Australia and I currently run 3cx with 6 PSTN phone lines (currently using 6 SPA3000's as PSTN Gateways).
    I find that these can be flakey at times...
    I'm after a PSTN gateway that will work well with Australian lines and 3CX (also with the ablity to point any of the lines to different call queues or extentions.
    Any ideas/Recommendations?
  2. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    As Matt has mentioned - the Patton 4114 would be your best option.
    It is our standard offering in NZ - our Australian office could assist you if you needed advice.
