3cx Auto Provisioning T46G
Discussion in '3CX Phone System - General' started by dangmoss, Oct 9, 2014.
  1. dangmoss
    Oct 9, 2014
    26
    This is my 3rd or 4th 3cx install and I have come across an odd problem.
    I have the latest 3cx (activated with 8sc).
    I have Yealink T46G phones.
    All are on the same subnet, same switch actually.
    But some odd reason they don't show up under 'phones' so I can just assign them to an extension.
    I have tried the latest firmware.
    I have tried a different switch.
    Fooling around with it and rebooted several different parts at different times has resulted in at best 3 out of 4 phones showing up.
    What gives?
  2. 805tech
    Aug 30, 2013
    39
    Have you tried restarting all the services under the Service Status section? Caution if you do restart all the server make sure no one is on a phone call. It will bring down everything until everything is restarted.
  3. dangmoss
    Oct 9, 2014
    26
    Ya several times
    It's a new install
    I even tried a new 3cx install on a different pc
    I have had some success by downgrading firmware on t46g to the 3cx one they list ends in 228 I think
  4. Jessep
    Oct 9, 2014
    25
    Have you tried a factory reset on the phones and starting the provisioning process from scratch?
  5. dangmoss
    Oct 9, 2014
    26
    Yep
    31 new phones
  6. Jessep
    Oct 9, 2014
    25
    I would still factory reset the troublesome phones, something may have gone a little sideways in the initial provisioning attempt.
  7. dangmoss
    Oct 9, 2014
    26
    Oh I did
    Lots and lots
    Upgraded and downgraded firmware
    Different router
    Different switch
    Gonna pull my hair out
  8. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Why not manually provision?
  9. dangmoss
    Oct 9, 2014
    26
    ya ofcourse
    I would rather not for 31 phones
    something isnt right...
    looks like downgrading to 228 fixes it
