3CX Backup Logs
Discussion in '3CX Phone System - General' started by dbaird, Oct 1, 2011.
  1. dbaird
    Apr 20, 2011
    We are running 3CX v10 (SP3). I had previously set up 3cx to save backup logs, as we were troubleshooting a QoS issue. I have since un-ticked the option to "Keep Backup of Log Files," and applied the settings. However, 3cx continues to write the log files. Any known solutions?
    Thanks,
    Daniel
  2. paul1
    Jan 14, 2010
    80
    After changing the log settings you need to restart the services for the new settings to take effect.
