3cx Backup - Notify on Fail Only
Discussion in 'Ideas' started by craigreilly, Apr 18, 2017.
3cx Backup - Notify on Fail Only 5 5 66votes
5/5, 66 votes
  1. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,321
    253
    Would like preference to email me on Backup Failure Only. I get so many Success Emails, that I start to ignore them.
    Please make this as part of the scheduling options. Sometimes, I may want to see Success and Fail, or Only Fail, etc.
    JerN, IetSInfo, Rich.Hopkins and 2 others like this.
  2. Sophie Ramos
    Mar 21, 2017
    5
    This is a great idea! Being able to choose which kind of emails (Failure/Success) to receive is much more manageable than receiving all of it. I hope this idea goes through and gets implemented.
    craigreilly likes this.
  3. BartLanz
    Apr 17, 2017
    7
    I too would like to see this happen!
  4. lutz
    Jul 30, 2013
    6
    +1 for me
  5. V..
    V..
    Feb 14, 2017
    74
    28
    One thing you may want to consider though is if you do not receive an e-mail how can you know for sure that the backup ran. Are you not able to setup a rule on your email client to file them away but still give you the ability to check the history of the job?
  6. craigreilly
    Feb 1, 2012
    3,321
    253
    If it didn't run then it failed. 3cx should be able to "see" that no backup was created and send the email.
  7. Dave-TTG
    May 15, 2017
    26
    9
    Also please add the ability to edit the "Scheduled Backup Failed!" email template and add a customer/server name, because at the moment it doesn't show in the body of the email or subject which server generated the alert. Not a big deal when you've got only one 3CX to look after, but when you've got hundreds that all send to a central alerts mailbox then you've got problems
    You can just check the email headers for the sender WAN IP and match it up using that, but there has to be an easier way :)
    jbryant84, supsol and craigreilly like this.
  8. ChrisHerrmann
    Jul 13, 2017
    8
    +1 currently it's unusable with any level of volume.
  9. Tom Howard
    Feb 2, 2018
  10. Charlie Osborne
    May 22, 2017
  11. Neturius
    Dec 8, 2016
    18
  12. aws2p
    Jan 9, 2014
    43
    6
    On 3CX scheduled backup to FTP server , i experienced to receive succesfull backup emails when backup were not done, on destination folder just a 0 byte file created, so clearly i don't trust the 3CX process to check if there's a real backup done. Email give no waranty you have done a backup.
  13. lcircle
    Dec 12, 2017
    9
  14. billthenerd
    Jul 3, 2014
    19
  15. mikeimpo
    Dec 9, 2015
    12
    7
  16. dpink
    Jun 27, 2017
    12494 Member
    Apr 16, 2010
    298
    29
    +1
  18. Rich.Hopkins
    Mar 27, 2018
    6
    Would also like to see this implemented.
    I'm currently using this strategy for our Data Backups.
    I only want to know if something needs fixing, not that it worked as expected.
    We're in danger of information overload!
  19. Kevinrek
    Nov 22, 2017
    9
  20. giwm
    giwm New Member
    Sep 27, 2016
    236
    41
    Backup AND recovery on fail only. With latest version, we no longer get the successful recovery emails, so... hopefully it's not failing either. But I'd have to manually check every day.
