3CX Backup Patch
Discussion in '3CX Phone System - General' started by garethb_83, Mar 2, 2010.
  1. garethb_83
    Oct 11, 2007
    25
    Hi, Does anyone know where I can download the 3CX Backup patch for version 8.0.9908. I'm wanting to upgrade to the latest version but read somewhere that the backup/restore deson't work without applying a patch. Or was this just upgrading to the next release after this?
    Many Thanks
    Gareth
  2. StaffKB
    Jan 5, 2010
    97
    Hi there,
    Please open us a support ticket so that we can send you the patch.. However if you have a backup previous to upgrading to 8.0.09908 then i suggest you use that backup (if you havent done any major changes.)
