3CX Backup
Discussion in '3CX Phone System - General' started by gbg2001, Feb 8, 2009.
  1. gbg2001
    Mar 18, 2008
    11
    Hi there
    Firstly thanks to those who helped me with my last problem posted here, I really and so greatful for all the help and advise.. Cheers
    I just wanted to know is it possible to initiate a backup of my 3CX installation from another PC rather than the one the 3CX is installed on.
    I have 3CX on a PC in the loft, and do not really want to keep running up there to back it up each day, I know I can use Tasks to run an auto backup, but I like to use a dirrent name on each backup so I can keep many of them..
    So I would like to site by the fire using my laptop and start a backup just as though I was in the cold loft doing :)) :shock:
    Cheers
    Glen
  2. gbg2001
    Mar 18, 2008
    11
    Thanks for that.. I was hoping to use the Backup program that comes with 3CX, as it is better intergrated for doing a restore....
    But again thanks a lot
    Glen
  3. nb
    nb Support Team
    Jun 7, 2007
    2,153
    171
    Enable remote desktop on the loft machine and rdp to the machine from downstairs.
    Then Trigger a backup normally.
  4. gbg2001
    Mar 18, 2008
    11
    Thanks for all the help..
    I have ended up using Remote Desktop, not waht I wanted but does the job A OK.. Cheers again
    Glen
