3CX backups corrupted!
Discussion in '3CX Phone System - General' started by Camal, Jul 16, 2015.
  1. Camal
    Sep 12, 2013
    5
    A thunderstorm killed my PBX, and I'm now trying to restore it on new hardware. The BIG problem is that 3CX tells me all my backups are corrupted! I have 3 different backups saved and they are all corrupted according to 3CX... how is this even possible?? I can't extract the zip's manually either, this is a disaster!
    This is the batch file I have used to make the backups:
    Code:
    @echo off
    echo Launching 3CX backup system…
    set hr=%time:~0,2%
    if "%hr:~0,1%" equ " " set hr=0%hr:~1,1%
    3CXBackup.exe backup "C:\# Backups\3CX\3CXBackup_%date:~0,4%%date:~5,2%%date:~8,2%_%hr%%time:~3,2%%time:~6,2%.zip" /callrecordings /voicemails /voiceprompts /callhist /exit
    The backups are at saved locally first and are then copied to a NAS.
    Is there something wrong with the way I have been doing backups?
    Is there any way I can fix this or am I screwed?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,412
    274
    / are not valid characters in filenames. Although perhaps your language settings are using something different.
    do an echo on
    Code:
    Try this as a start. It works for me.
    Code:
    REM @echo off
    REM Keep 10 days of backups on Local.
    cd\
    cd "C:\3cxBackup\"
    forfiles.exe /p C:\3cxbackup /s /m *.zip /d -10 /c "cmd /c del @path"
    set today=%date:~-4%%date:~4,2%%date:~7,2%
    set timed=%time:~0,2%_%time:~3,2%_%time:~6,2%
    cd "C:\Program Files\3CX PhoneSystem\Bin\"
    3CXBackup.exe backup C:\3CXBackup\3CX.%today%%timed%.zip /callrecordings /voicemails /voiceprompts /callhist /firmware /exit
    REM Now copy this to Backup Device or USB
    SET today=
    SET timed=
    exit
  3. Camal
    Sep 12, 2013
    5
    Thanks!
    I've managed to find another older backup which worked, so thankfully I no longer need to jump from the roof tonight (pheeeew!!)
    The strange thing is I have not changed anything with the backup procedure and it has worked flawlessly before, but the last three backups has for some reason become corrupted. I need to investigate this further when I have evertything up and running again.
