- Joined
- Oct 10, 2006
- Messages
- 12
- Reaction score
- 0
I have successfully set up a 827H router to use on my ADSL account.
I have working port forwards for FTP,Bittorrent,HTTP and Mail.
What I am having trouble with is my 3CX pbx.
I have traversed NAT by forwarding all ports relevent to my pbx but I
still can not register the 2 SIP accounts I am using.3CX works just fine with my Draytek router but it supports UPnP which of course Cisco doesn't.
I have searched everywhere for a solution and have not found one.
The only documentation I found on this for 3CX is in the faqs of this Site but is for the Web Setup path not CLI.
I am thinking I may have to add a ACL for SIP but I am not sure.
If any of you are using 3CX behind a Cisco Router could you look at my config below to see where I have gone wrong.
I also have done a #show version to allow you to check my version of IOS.
gateway1#show version
Cisco Internetwork Operating System Software
IOS (tm) C820 Software (C820-OY6-M), Version 12.2(4)YA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Synched to technology version 12.2(5.4)T
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Thu 11-Apr-02 16:24 by ealyon
Image text-base: 0x80013170, data-base: 0x806A92CC
ROM: System Bootstrap, Version 12.2(4r)XM2, RELEASE SOFTWARE (fc1)
ROM: C820 Software (C820-OY6-M), Version 12.2(4)YA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
gateway1 uptime is 44 minutes
System returned to ROM by power-on
System image file is "flash:c820-oy6-mz.122-4.YA2.bin"
CISCO C827H (MPC855T) processor (revision 0x401) with 31744K/1024K bytes of memory.
Processor board ID FOC06240PUX (3980510627), with hardware revision 0000
CPU rev number 5
Bridging software.
1 Ethernet/IEEE 802.3 interface(s)
1 ATM network interface(s)
128K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
2048K bytes of processor board Web flash (Read/Write)
Configuration register is 0x2102
gateway1#show running-conf
Building configuration...
Current configuration : 2997 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
no service password-encryption
hostname gateway1
enable secret 5 $1$jQMx$jJeZ1iATM5tfakR5pXg7u/
enable password ********
ip subnet-zero
ip name-server 203.12.160.36
vpdn enable
vpdn-group pppoe
request-dialin
protocol pppoe
ip mtu adjust
bridge irb
interface Ethernet0
description LAN
ip address 192.168.10.1 255.255.255.0
ip nat inside
no keepalive
no cdp enable
hold-queue 32 in
hold-queue 100 out
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
description WAN
pvc 8/35
pppoe-client dial-pool-number 1
interface Dialer0
no ip address
no cdp enable
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname **********@nsw.exetel.com.au
ppp chap password 7 08354D570B0B0C03065A54547C
ip nat inside source list 101 interface Dialer1 overload
ip nat inside source static tcp 192.168.10.10 5061 interface Dialer1 5061
ip nat inside source static tcp 192.168.10.10 21 interface Dialer1 21
ip nat inside source static tcp 192.168.10.10 22 interface Dialer1 22
ip nat inside source static tcp 192.168.10.2 49152 interface Dialer1 49152
ip nat inside source static tcp 192.168.10.10 25 interface Dialer1 25
ip nat inside source static tcp 192.168.10.10 110 interface Dialer1 110
ip nat inside source static tcp 192.168.10.10 6080 interface Dialer1 6080
ip nat inside source static tcp 192.168.10.10 5060 interface Dialer1 5060
ip nat inside source static tcp 192.168.10.10 9000 interface Dialer1 9000
ip nat inside source static tcp 192.168.10.10 9001 interface Dialer1 9001
ip nat inside source static tcp 192.168.10.10 9002 interface Dialer1 9002
ip nat inside source static tcp 192.168.10.10 9003 interface Dialer1 9003
ip nat inside source static udp 192.168.10.10 9003 interface Dialer1 9003
ip nat inside source static udp 192.168.10.10 9002 interface Dialer1 9002
ip nat inside source static udp 192.168.10.10 9001 interface Dialer1 9001
ip nat inside source static udp 192.168.10.10 9000 interface Dialer1 9000
ip nat inside source static udp 192.168.10.10 5060 interface Dialer1 5060
ip nat inside source static udp 192.168.10.10 5004 interface Dialer1 5004
ip nat inside source static udp 192.168.10.10 5005 interface Dialer1 5005
ip nat inside source static udp 192.168.10.10 3478 interface Dialer1 3478
ip nat inside source static udp 192.168.10.10 5482 interface Dialer1 5482
ip nat inside source static udp 192.168.10.10 5061 interface Dialer1 5061
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
access-list 101 permit ip 192.168.10.0 0.0.0.255 any
dialer-list 1 protocol ip permit
snmp-server community y RO
bridge 1 protocol ieee
bridge 1 route ip
line con 0
exec-timeout 0 0
stopbits 1
line vty 0 4
exec-timeout 120 0
password ********
login
length 0
scheduler max-task-time 5000
end
Cheers,
Fallout
CPU rev number 5
Bridging software.
version 12.2
no service pad
hostname gateway1
ip subnet-zero
vpdn enable
vpdn-group pppoe
request-dialin
protocol pppoe
ip mtu adjust
bridge irb
interface Ethernet0
description LAN
ip nat inside
no keepalive
no cdp enable
hold-queue 32 in
hold-queue 100 out
interface ATM0
no ip address
description WAN
pvc 8/35
interface Dialer0
no ip address
no cdp enable
interface Dialer1
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ip classless
ip http server
bridge 1 route ip
line con 0
exec-timeout 0 0
stopbits 1
line vty 0 4
exec-timeout 120 0
password ********
login
length 0
end
Cheers,
Fallout
