3CX behind Cisco ASA
Discussion in '3CX Phone System - General' started by allTel, Apr 8, 2010.
  1. allTel
    May 9, 2009
    14
    I have a 3CX server going in behind a Cisco ASA 5510 - I can't seem to connect (outbound or inbound) to my CallCentric sip account. Does anyone know the working configuration for the ASA? I keep receiving an error that says No RTP packets were received:
    No RTP packets were received:remoteAddr=192.168.40.25:40008,extAddr=0.0.0.0:0,localAddr=192.168.40.5:7008
    I suspect this is the Cisco ASA blocking the call - I have setup a NAT policy to map the ext address to the internal server address and created a security policy to allow traffic to the external address?? CallCentric shows the server registered with the correct external address.
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Please post the results of the firewall checker this will allow us to see if any ports are blocked and if so direct you in the correct direction to troubleshooting the issue.
  3. cmcghee
    Jun 26, 2009
    ..also can you post the relavant parts of your ASA config?
  4. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    ...even 3CX Phone system log can provide some information :)
