3cx bihind nat nat
Discussion in '3CX Phone System - General' started by feestbeestzaandam, Nov 18, 2009.
  1. feestbeestzaandam
    Jun 6, 2009
    10
    I have a problem
    I have 3cx server behind a internet connection with a nat 192.168.1.x with ip 192.168.1.16
    I have on 1 fritzbox and 3 softphones connected on that same nat 192.168.1.x
    On a other internet connection i have 1 fritzbox and 1 softphone connected.
    I can call to from all the phones with nat 192.168.1.x to the other phones wit nat 192.168.1.x
    and i can call to the other internet connection with nat 192.168.1.x
    The sound is oke and it rings so 100% oke
    But when i try to call from a phone from nat 192.168.1.x to a other phone/fritzbox in that nat( 192.168.1.x)
    then i have only ringing but no sound.
    Now i have tryed to change the ports on the nat
    so that (192.168.1.2) the soft phone got the ports 7000 to 7500
    and then i have sound wehen i call.
    But when i call with a other ip then 192.168.1.2 to the other internet connection with nat 192.168.1.16 i cant hear them
    what am i doing wrong and can i solv it??
    The rtp ports are 7000 to 7500
  2. DeWild1
    Oct 31, 2008
    86
    Try to put it on tunnel
