Solved 3CX Bridge ports
Discussion in '3CX Phone System - General' started by THCO, Feb 27, 2018.
  1. THCO
    May 16, 2017
    57
    11
    I have a stupid question.
    I have 2 Servers that are both on standard. When I build a bridge between the two what ports need opened up in the firewalls. I think I understand that that since I have standard I cant send presences across to each other.
    Is 5060 the only ports I need or do I need 9000-9500?
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,248
    202
    #2 Saqqara, Feb 27, 2018
  3. mariosM_3CX
    mariosM_3CX Support Team
    Nov 1, 2017
    406
    40
    Hello @THCO
    If you are using the tunnel protocol for your bridge then as @Saqqara said, you just need the port 5090, as both sip and rtp traffic will use this port.
    If however you do not use the tunnel, then you'll need 5060 and 9000-9500 as well. Note that all these ports should already be open if you are using a voip provider.
  4. THCO
    May 16, 2017
    57
    11
    I have these open to just my voip provider only to harden my server. I dont use remote extentions. Please feel free to close this.
