3CX Bridge
Discussion in '3CX Phone System - General' started by 3CX Central America, Feb 27, 2018.
  1. 3CX Central America
    Feb 14, 2018
    13
    How can I bridge two 3CX PBXs directly without using tunnels?
  2. mariosM_3CX
    mariosM_3CX Support Team
    Nov 1, 2017
    401
    36
  3. 3CX Central America
    Feb 14, 2018
    13
    Thank you. Should I use port 5060 if I decide not to use tunnels?
  4. mariosM_3CX
    Nov 1, 2017
    401
    36
    By default 5060 will be used if you chose not to use the tunnel, but you can change this.
  5. 3CX Central America
    Feb 14, 2018
    13
    Okay, master and slave bridges have been configured on their respective PBX, however, the bridges do not want to register. What can be the cause of the bridges not registering?
    Note that IP connectivity exists between the two bridges.
  6. leejor
    10,375
    231
    Check the 3CX Activity log at the Master end. Is there a log showing a registration attempt? Error message (blacklisted IP/bad password) ? If not, check the log at the Slave end. Do you see a registration attempt? Does the Domain/IP/port of the Master end look to be correct?
  7. 3CX Central America
    Feb 14, 2018
    13
    I've checked all of the above and they are all correct, however, there is still no registration attempt. What exactly does 3CX consider to be a direct bridge?
  8. jimbo59
    jimbo59 Member
    Nov 17, 2017
    358
    77
    They must have the same virtual extension number.
  9. leejor
    10,375
    231
    Are there no logs at the Slave end showing a registration attempt (and failure) ? If not, then you may need to review the settings, at least at the Slave end, as a start.
  10. 3CX Central America
    Feb 14, 2018
    13
    The major configuration on the slave end are as follows:
    • Virtiual extension number is the same virtual extension number used on the master
    • No outbound prefix is set as the master will use a different range from the slave.
    • Authentication password is the same as the authentication password used on the master.
    • Remote PBX IP and port is public IP:5060 where public IP is the IP of the master.
  11. mixig
    mixig Active Member
    Dec 13, 2011
    519
    11
