3CX Call assistant doesn't work
Discussion in '3CX Phone System - General' started by federicom, Oct 24, 2007.
  1. federicom
    Oct 24, 2007
    16
    I have tried to use the call assistant but seem that cannot be able to login to server. Any workaround, tips, suggestion will be really appreciated. Thank you. Federico
  2. tab
    tab
    Aug 10, 2007
    85
    You should try with the default password of voicemail.
    tab
  3. federicom
    Oct 24, 2007
    16
    Where ? In voice mail PIN ? I've tried but the client doesn't work. It seem that it does not reach the server.
