3cx Call Control Api - Add Codecs to Extension
Discussion in '3CX Phone System - General' started by gehtmaguad, Apr 3, 2018.
  1. gehtmaguad
    Nov 22, 2017
    I'm trying to create new extensions and associate them with existing codecs. I'm creating the extension with the following code:
    newExt = PhoneSystem.Root.GetTenants()[0].CreateExtension(newExtNumber);
    newExt.FirstName = newExtFirstName;
    newExt.AuthPassword = newExtPassword;
    newExt.AuthID = newExtAuthId;
    newExt.Save();
    However, I haven't found a way to associate the extension with one or more of the defined codecs.
    I also tried doing it the other way around, fetching the codecs first and then assign them extensions.
    However, there seems no way to do this either:
    foreach (Codec c in PhoneSystem.Root.GetCodecs())
    System.Console.WriteLine("Codec: " + c.ToString());
    // Access extensions associated with codec
    Is there a way do create a relationship between codecs and extensions using the Call Control Api?
    Kind regards
    Markus Hösel
