3CX Call History Service Error
Discussion in '3CX Phone System - General' started by siraj, Aug 18, 2014.
  1. siraj
    Aug 18, 2014
    Below please find the error i found from call history service log!
    due to this problem i can't get the call log data's!
    there is no data in data base hence i cannot get the call logs and reports!
    i have been struggling for more than a week with this issue still couldn't find a solution!
    any one there who can help me! please!
    Code:
    2014/08/18 08:55:12.038|0007|Erro(01)| Bad DB connection string
    2014/08/18 08:55:12.038|0007|Warn(03)| System.Exception: Timeout while getting a connection from pool.
       at Npgsql.NpgsqlConnectorPool.RequestPooledConnector(NpgsqlConnection Connection)
       at Npgsql.NpgsqlConnectorPool.RequestConnector(NpgsqlConnection Connection)
       at Npgsql.NpgsqlConnection.Open()
       at GenericUtilsNet.DBManager.Init(String conxStr)
    2014/08/18 08:55:12.038|0007|Erro(01)| Database Conx failed = Timeout while getting a connection from pool.
    2014/08/18 08:56:12.043|0007|Info(03)|   Database Conx string = Server=localhost; Port=5480; User Id=phonesystem; Database=phonesystem; Timeout=1024;
    2014/08/18 08:57:50.716|0022|Info(03)| Detected profile change from Away to Available for extension:124
    2014/08/18 09:01:48.783|0008|Info(03)| VMMonitor: alive (iter=3671)
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Hi there,
    What version of 3CX Phone System are you running?
    Is your management console working ? Are all services started?
  3. siraj
    Aug 18, 2014
    I am using 3CX Phone System v12
    Yes Management console is working and all the service are started!
  4. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Are you running latest service pack available (SP6.1 at the moment) ?
  5. siraj
    Aug 18, 2014
    Yes! Finally we got the support from 3CX as it was a problem with License Key! after what ever they did! they told us to activate again with the same KEY and now the problem has been rectified!
