3CX call out with a different numbers
Discussion in 'Windows' started by engkim, Feb 24, 2014.
  1. engkim
    Feb 24, 2014
    Hi all below is my example:
    My 3CX phone system gateway number is 03-97971234
    When i call out i want the number will be display 03-97978765 which is not in the 3CX phone system
    Can i know whethere it is possible to do it?
    Regards,
    Kim
    11,079
    324
    Changing the outgoing displayed number requires two things...
    An outgoing VoIP trunk.
    A VoIP provider that allows this (some don't).
