3CX Call Pickup(Ver 6)
Discussion in '3CX Phone System - General' started by qaisdev, Jul 9, 2008.
  1. qaisdev
    Apr 7, 2008
    33
    Please can anyone tell me , if call pickup works in version 6.As in our case it is not workling at all.
    Any help will be appreciated.
    Kind Regards
    Qais
  2. Anonymous
    Anonymous Guest
    Call pickup works using the *20* code.
    This feature is only available in the commercial version.
    Thanks,
  3. Nebula
    Nebula New Member
    Apr 6, 2008
    116
    Works fine for me, V6.0.612.0
  4. qaisdev
    Apr 7, 2008
    33
    Thx for the reply.I did manage to make it work.Actually there was something wrong with dial plans and after fixing it wahaaaa it worked.
    Qais
  5. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hi qaisdev
    Can you tell me you fix it ?
    because I have same problem with all Linksys devices
    Thank you
  6. francesco
    francesco New Member
    Jun 23, 2008
    102
    can you post your dial plan?
  7. qaisdev
    Apr 7, 2008
    33
    I tried a lot and at then figured it out that it is better to check the ini file and amend the config there.
    Try to change it there first.
    ps:Which linksys device are u using?
