3CX Call Reporter SQL?
Discussion in '3CX Phone System - General' started by Kathryn, Apr 14, 2015.
  1. Kathryn
    Apr 14, 2015
    I'd like to link the 3CX Call Reporter to either Orbis Taskcentre (to get automated reports) or Tableau (to get visual analytics) - has anyone had any experience of doing this and can anyone help me with SQL info?
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi Kathryn,
    No direct access to the database is supported, you need to either use manual export of the reports to CSV/others formats, or use the CDR output so that the call logs can be read live by an external app.
