3cx call
Discussion in '3CX Phone System - General' started by stash, Mar 16, 2012.
  1. stash
    stash New Member
    Feb 23, 2012
    213
    Anyone tried to use BLF to distinguish a DID number?
    scenario:
    i have one CSR handling 4 different accounts every account has one DID
    1 - Cisco Inquiry
    2 - Dell Inquiry
    3 - Hp Inquiry
    4 - IBM Inquiry
    The thing i want to accomplish is when someone called in cisco the CSR knows that the call is coming from Cisco Inquiry.
    Where can i do this? or does 3cx support this kind of feature? I will use a IP phone
    Thanks,
    STASH
    11,113
    329
    You can run the DID's through different ring-groups and then apply that ring-groups name to the CID.
    http://www.3cx.com/forums/appending-ring-group-name-after-caller-id-8200.html
    It's an old post
    Or you could direct each DID to a different extension key on the set. If key 2 was ringing then they would know that it was a call regarding Dell, etc.
