3CX Caller ID
Discussion in 'Windows' started by techking, Jul 24, 2009.
  1. techking
    Jul 24, 2009
    11
    I am running 3cx voip client free edition but whenever i place a call, only the # displays on the receiver's end. Can you plz help me?
    10,368
    228
    You are making an outgoing call over what type of service, a VoIP provider?
  3. techking
    Jul 24, 2009
    11
    First of all thank you for responding. I am placing an internal call. It is a small office setup with only local network.
  4. leejor
    10,368
    228
    Are you saying that only the extension number shows up , no name? Or the "#" shows up? Have you tried putting a name against each extension in the datafill? What sort of phones/ATA's are you using? What type of caller ID do the phones handle? Some counties caller ID doesn't handle name display.
  5. techking
    Jul 24, 2009
    11
    Only the extension numbers show up. I am using only the soft phone and the free version of 3cx
  6. voipbaennjer
    Jul 10, 2009
    44
    What do you expect it to display? On an intermal call at least the ext. number is shown. The 3CX softphone should be able to display the name as well if it's put in under "preferences / caller ID" .
  7. techking
    Jul 24, 2009
    11
    Yes the ext number shows. But I want to know how can I make the Caller's name show up. I am using 3cx voip client btw.
  8. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,406
    81
    Just go in the Caller's Extensions and Add Names / Last names where it asks for it.
    When that person calls you you will see both his name and Number.
      File size:
      65.4 KB
      2,784
  9. techking
    Jul 24, 2009
    11
    I have done that but it doesnt show. Do you think its because I am using the free version?
  10. techking
    Jul 24, 2009
    11
    Ok guys update I tried using the 3cx Voip Phone and the caller ID worked perfectly. But When I use the 3cx Voip Client it doesnt work. I am currently doing internship, I am trying to get a company to buy this software. But I need to get the caller ID feature working
  11. leejor
    10,368
    228
    The free version will show name. What country do you live in ? Not all caller ID devices (attached to an ATA) in all countries are capable of name display.
  12. techking
    Jul 24, 2009
    11
    Well that shouldn't be the problem because I am only running an internal voip system.
  13. techking
    Jul 24, 2009
    11
    3CX VoIP Client (v6/v7) doesn't had/has this feature, to display the caller ID.
    We will implement this feature in our new softphone, 3CX VoIP Phone - It will be available very soon, stay tuned :)
    I just found that on on older post. It seems that the caller Id feature is not available on v7
  14. voipbaennjer
    Jul 10, 2009
    44
    When calling from the 3CX VOIP Phone to my Grandstream GXP280, GXP1200, Siemens C470IP, T-Home Sinus 501V I can see the callers name set under "preferences". My Linksys SPA962 doesn't show the name, only the callers number.
    When I call the 3CX VOIP Phone (V 3.1.6288.0) I can only see the callers number.
  15. leejor
    10,368
    228
    It sounds like an issue with the set itself.
  16. voipbaennjer
    Jul 10, 2009
    44
    Update: I setup a scenario with 2 3CX VOIP Phones on 2 different PCs.
    When I call from one 3CX VOIP Phone to the other it shows both internel number and the name set under preferences.
      File size:
      58 KB
      1,776
  17. techking
    Jul 24, 2009
    11
    i managed to get the caller ID feature to work quite fine on the 3cx voip phone. However, when i try it on the voip client it only shows the ext number
  18. LeonidasG
    Nov 19, 2008
    1,406
    81
    This might Solve your questions regarding why the Voip Client is not working like the Voip Phone.
    http://wiki.3cx.com/downloads
    Meaning we no longer support the Voip Client, it has been effectively been replaced with the Voip Phone and no Updates are being made to the Voip Client anymore.
    I hope that answers your questions.
  19. techking
    Jul 24, 2009
    11
    Thanks a lot for this information. I will now replace all 3c. voip client software with the voip phone software. I must say that I loved the interface on the voip client software though
  20. techking
    Jul 24, 2009
    11
    We arent using any hardphones as yet. Will will test out the software for a month and then decide whether or not we want to buy it along with the hardphones required.
