3CX calls no existing phone number AS EXISTING ???!!
Discussion in '3CX Phone System - General' started by gecomail, Apr 14, 2008.
  1. gecomail
    Apr 11, 2008
    14
    I have tested installation of 3cx (latest version) of 4 pc.
    If i call a non existing number (outside), 3CX not comunicate that this is no good number, but ring as normal call.
    Someone have solved this problem. Thank you Buono Jury.
  2. h2009
    h2009 Member
    Mar 15, 2008
    447
    this is down to the the way your sip provider looks for that number, not 3CX. 3CX will return with a semi busy tone if the line is dead/no number.
  3. gecomail
    Apr 11, 2008
    14
    no it's 3cx, because i have test with single ip phone Linksys spa 942 with account that i have use in 3cx (and the same voip services provider), and this phone work fine. (404 if the called number is no existing, o busy if i call busy number).
