3CX can support Quintum DX as PSTN T1 Gateway
Discussion in '3CX Phone System - General' started by alexccy, Dec 25, 2008.
  1. alexccy
    Dec 25, 2008
    May i know any one try this?
    3CX can support Quintum DX as PSTN T1 Gateway?
    or
    Any suggest for PSTN T1 Gateway ?
    Alex
  2. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    The Patton 4960 series or the Sangoma cards are tried and tested with 3CX on a T1. The Patton model number will vary based on number of ports and channels you require.
    http://www.3cx.com/voip-gateways/sangoma.html
    http://www.3cx.com/voip-gateways/patton-sn4960.html
