3cx can work for android but not iphone
Discussion in 'iOS' started by chuakwee, Sep 5, 2011.
  1. chuakwee
    Sep 5, 2011
    I have setup my 3cx phone. It works for android phone but not iphone. Is there any special setting i need to handle for iphone?
    Thanks.
  2. willow
    willow Member
    Mar 1, 2011
    471
    There is no special setting, just remember that the android supports tunneling over 5090 and the iphone does not as of yet. so it needs to be over 5060 and the real rtp ports of 9000-9049.
