3cx cannot send symbol # in number
Discussion in '3CX Phone System - General' started by linker, Sep 2, 2011.
  1. linker
    Sep 2, 2011
    Hi.
    3CX have strange bug. If you configure to send for example 1111#444444 where 1111# is tech prefix 3cx send
    1111%2344444444.
    As i understand 3CX just not correctly work with UNICODE. because symbol # in unicode #
    and 0x23 in hex
    Does anybody know how to fix ?
    Small example of tcpdump (changed only ip adresses of orig and term party ):
    INVITE sip:30537%2331254310133@1.1.1.1:5061 SIP/2.0
    Via: SIP/2.0/UDP 192.168.252.60:5060;branch=z9hG4bK-d8754z-907ffa181c104955-1---d8754z-;rport
    Max-Forwards: 70
    Contact: <sip:31443787799@2.2.2.2:5060>
    To: <sip:30537%2331254310133@1.1.1.1:5061>
    From: "31443787799"<sip:31443787799@1.1.1.1:5061>;tag=6c48b315
    Call-ID: OTc5Yjk4ODU2MmIxNmYyYWFiODE3OGM1Y2JiMDc4MDE.
    CSeq: 1 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
    Content-Type: application/sdp
    Supported: replaces
    User-Agent: 3CXPhoneSystem 10.0.20085.0
    Content-Length: 308
    But normally it must be
    INVITE sip:30537#31254310133@1.1.1.1:5061 SIP/2.0 etc
  2. nbailey
    nbailey Member
    Jan 31, 2011
    359
    3CX strips anything not numbers, this is not a bug but by design. It doesn't allow ' in names or other characters. Only the SKYPE prefix for dialing skype numbers. This is a security risk if we allow special characters to be dialed. The % is the space left when it stripped the pound sign.
    Thanks,
    Nate
  3. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    It is defined in RFC3261:
    alphanum = ALPHA / DIGIT
    unreserved = alphanum | mark
    mark = "-"|"_"|"."|"!"|"~"|"*"|"'"|"("|")"
    escaped = "%" HEXDIG HEXDIG
    SIP-URI = "sip:" [userinfo] hostport uri-parameters [ headers ]
    userinfo = (user|telephone-subscriber) [ ":" password ] "@"
    user = 1*(unreserved|escaped|user-unreserved)
    user-unreserved = "&"|"="|"+"|"$"|","|";"|"?"|"/"
  4. linker
    Sep 2, 2011
    It is all good
    but look on table 19.1.2 Character Escaping Requirements in RFC 3261
    user -- o o o o o o
    password -- o o o o o o
    host -- m m m m m m
    port (1) o - - o o o
    user-param ip o o o o o o
    method INVITE - - - - - o
    maddr-param -- o - - o o o
    ttl-param 1 o - - o - o
    transp.-param (2) o - - o o o
    lr-param -- o - - - o o
    other-param -- o o o o o o
    headers -- - - - o - o
    For INVITE it must not be escaped.
  5. leejor
    10,744
    281
    Yes, I came across this frustration a couple of years back when trying to send a PSTN feature activation code (78#) to a SPA3102 FXO. It is unfortunate that there has (so far) not been a way around this.
  6. linker
    Sep 2, 2011
    hm. I am not right
  7. SY
    3CX Support
    Jan 26, 2007
    1,825
    You are right, but context of 19.1.2 is specified in context on 19.1.1
    What is wrong and what is right in your specific case?
    Let's talk about concrete things.
