3CX - Can't update, dns fail
Discussion in '3CX Phone System - General' started by Fred Garcia, Nov 27, 2017.
  1. Fred Garcia
    Nov 27, 2017
    5
    I have a strange problem. My Debian can access to internet, I can update with apt-get update, The nslookup work (the ping is forbiden).
    But, When a update is available on the 3CX, It's not work. I have this message "Unable to contact the 3CX update server. Please check your internet connection and try again".
    I Can affirm my 3CX can access to Internet, or else all my users will knock ot my door ! My calls works perfectly (in and out.)
    Regards,
  2. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    219
    Try setting 8.8.8.8 as DNS for your server, should work with 3CX.
  3. Fred Garcia
    Nov 27, 2017
    5
    I have tried it, but no success.
    I check the sources list. I think It's ok. I restarted the Nginx server. Same issue...
  4. jimbo59
    jimbo59 Member
    Nov 17, 2017
    357
    77
    Did you restart networking or the server after you put in 8.8.8.8 for nameserver?
    nginx has nothing to do with the 3CX update server.
  5. Fred Garcia
    Nov 27, 2017
    5
    Yes, I did it.
    I restarted all services.
    So, With my responsable, we changed the interfaces files for fail over, restarted the services and It's work now. It's very strange...
    I modified the apt sources files in /etc/apt/sources.list, because the files was empty.
    It's a mistery...
