3cx change Public IP
Discussion in '3CX Phone System - General' started by Tomas Raska, Dec 18, 2017.
  1. Tomas Raska
    Aug 18, 2017
    59
    6
    Hello
    when we want change 3cx Public IP, is it sufficient to change this address only in Network Settings?
    Must we restart services?
    DNS entry xxxxx.3cx.eu is changed automaticaly?
    Or what things we must too change?
  2. StefanW
    Jun 2, 2009
    1,222
    93
    just change it there and wait. It can take up to 6h depending of the DNS TTL until you see the changes in all DNS in the worked, but nothing else to do
