3cx client 7 internal EXT to EXT caller id
Discussion in 'Windows' started by TOMTECH, Jan 1, 2009.
  1. TOMTECH
    Dec 28, 2008
    8
    Hi there, I'm running 3cx v7 Server and running 3cx client v7.0.4184.0, and was wondering if the internal client to client feature i.e. EXT to EXT caller id is disabled in the free edition?
    I have a X-Lite Softphone version 3.0 build 47456 installed and can see the 3cx client caller id that I changed on it, but cannot see the X-Lite caller id that I changed, on the 3cx client 7, and cannot see the changed caller id's on the 3cx client v7.to 3cx client v7.
    I'd like to change the caller id from a EXT number to a Dept. name, and can't seem to get it to work useing the EDIT EXTENSION Feature in the management console, in the OTHER section, of the EDIT EXTENSION console.
    Thanks,
    Tom
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,476
    67
    Hi, Tom
    3CX VoIP Client (v6/v7) doesn't had/has this feature, to display the caller ID.
    We will implement this feature in our new softphone, 3CX VoIP Phone - It will be available very soon, stay tuned :)
  3. Vali_3CX
    Dec 12, 2008
    1,476
    67
    Hi, Matt
    Happy New Year :)
    We try to make 3CX Voip Phone lighter, faster, safer, handy-er, flexible-er, rich-er and nicer looking, compared at least to 3CX Voip Client 8)
    As I said to Tom - stay tuned :)
    vali
  4. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Good Luck
    and Happy new year
