3cx client and TSE system
Discussion in 'Windows' started by bluetel2, Jun 13, 2009.
  1. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    do you know if it's possible to install 3cx VOIP client on tse server ?
    i try to use, with sound mapping, but when i can open my client, it don't connect, "failed to initialised mic device and sound deviced.
    i know it's because i am on tse with mapping but it exist another solution ?
    thanks
  2. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    No one test this system ?
  3. comresource
    comresource Member
    May 22, 2009
    303
    Windows terminal services does not support input audio from a remote client by default. Windows 2008 R2, which is in beta is supposed to add this feature.
    http://blog.tmcnet.com/blog/tom-keating/microsoft/windows-server-2008-rds-does-voip.asp
    There are always third party solutions such as Citrix or 2X if you need this now.
  4. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    ok thank you very much
