3CX Client App for iPhone
Discussion in '3CX Phone System - General' started by Heath, Aug 19, 2017.
  1. Heath
    Heath New Member
    Aug 12, 2017
    107
    How do you log out of the 3CX app on the iPhone.
    Also is there a way on the App that if I place an outbound call I have a choice to have the call go through the app using Data Minutes, or through my cell minutes and the Caller ID of the PBX shows to the receiver??
    Also, If I'm on the App, how can I have the call moved to my IP Desk Phone and visa versa on the same extention..
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,399
    79
    For iPhones, to prevent the application from using data minutes, you can do this through your iPhone Settings > Cellular > 3CX, Disable or Enable. We have no native function to do this inside the application, we will however consider it after checking how feasible this is.
