3cx client doesn't show extension if there is more than 1 ip
Discussion in 'Windows' started by amartini, Mar 17, 2008.
  1. amartini
    Dec 28, 2007
    17
    HI,
    in my Windows Vista Business, the 3cx client doesn't show internal extensions and trunk, if I configure more than 1 ip address in my network card.
    Any suggestions?
    Marco
  2. amartini
    Dec 28, 2007
    17
    Hi, I installed the latest version and the problem persist.
