3CX Client Keeps defaulting to Softphone mode
Discussion in 'Windows' started by jmiller, Nov 17, 2016.
  1. jmiller
    Aug 1, 2016
    24
    5
    If I switch to CTI mode then the next time the software is closed and reopened it defaults back to softphone mode. Is there a way to change it so it defaults to CTI or remembers the last mode it was in? It is doing this on Yealink T48G and Polycom vvx 410's. Thanks!
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,400
    535
    Hello there,
    I assume you are on V15, if this is the case then:
    Choose the extension you want from the management console, edit it and navigate to the provisioning tab.
    Choose the 3CX client from the drop down list and scroll down to call control. Then pick IP Phone and click ok.
    All set
  3. jmiller
    Aug 1, 2016
    24
    5
    I knew I saw that somewhere. Yes, I am on v15. Thanks!
