3cx client not working correctly through tunnel
Discussion in 'iOS' started by next2, Jun 7, 2017.
  1. next2
    Apr 19, 2009
    24
    Hi all,
    Some problems with the iOS 3CX client :
    Using the app on the LAN, with wifi enabled: everything is OK
    Using the app over 4G, through 3CX tunnel : we are able to receive and make calls, but many features do not work : recent calls list is empty, the status says 'connecting' or 'timeout', the presence square is grey instead of green ...
    Any idea?
    Thanks!
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,444
    61
    1 - in the Management Console, verify if your extension is allowed to work ouside of LAN; if not, enable this option.
    2 - while connected on LAN, in the client "More" tap "Re-Provision" or
    3 - while connected on LAN, in the client "More" tap "Resend Credentials" - it will force th PBX to re-send you the Welcome eMail, or
    4 - in the Management Console, select your extension and re-send Welcome Email
