3cx client problems
Discussion in 'iOS' started by equintana, Feb 18, 2017.
  1. equintana
    Dec 20, 2010
    57
    I´m using 3cx iOS and Mac client outside from headquarters.
    Ports 5060 5061 5090 etc are open used this guide https://www.3cx.com/blog/docs/ports-used/, but I still can ´t connect using the software client.
    What is wrong?
    Regards
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,349
    274
    Hello @equintana
    Please make sure that you have tunnel enabled for your extensions that use port 5090. Also make sure you pass the firewall checker to eliminate any firewall issues.
    Also note that you will need port 5001 for presence.
