3CX Client Time Verification
Discussion in '3CX Phone System - General' started by tobiastromm, Apr 13, 2011.
  1. tobiastromm
    tobiastromm New Member
    Jun 26, 2010
    138
    Hi again :)
    On Softphones and ATAs I can change the "Register Expiration" to a time that I determine.
    There is a way to change the value of 3CX extension status verification? 3CX check if the extension is available?
    I need to change that because sometimes there is a network crash or a incorrect Softphone close error (or kill with CTRL + ALT + DEL) and the extension is still green on 3CX management console.
    Thank You.
    11,119
    329
    I seem to recall a while back, a post about changing the registration time that 3CX tells devices, to use. The default is 30 minutes. I've never changed that myself, but i had a look through the settings and there isn't any place obvious to make that change. I'm assuming that it is in one of the files somewhere. Had a search for it but didn't come across the post I remember. the responce, with the information you are looking for was from someone at 3CX.
