3CX Client Update Fails to negotiate SSL/TLS
Discussion in 'Windows' started by Thomas Miller, Apr 6, 2018.
  1. Thomas Miller
    Apr 6, 2018
    Hello All -
    I switched my users from Fonality to 3CX a couple of days ago. During testing, our PCI scan showed TLS 1.0 was enabled on the management interface. As this is now a failing condition, I disabled TLS 1.0 and 1.1 in the nginx.conf file and restarted nginx. Everything worked so I thought all was well. However, after bring users onboard, it now seems that without TLS 1.0 enabled, the Windows client cannot update. If I re-enable TLS 1.0, it works. Is there a fix for this that would allow me to disable the weak ciphers and still have the clients update?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,430
    539
  3. Thomas Miller
    Apr 6, 2018
    Thank you. I noticed a similar answer in another thread and was able to fix the issue by re-enabling TLS 1.0 and 1.1, allowing the update, then disabling. From the thread I saw, this will be the last time we will have to do this.
  4. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,558
    118
    Exactly.
