3cx Client with multiple phones (Yealink/Dect)
Discussion in 'Windows' started by Martijn, Jun 26, 2017.
  1. Martijn
    Jun 26, 2017
    5
    Hi a client of mine has a 3cx PBX with a couple extensies which has 2 phones connected.
    The first phone is a Yealink and the second is a Dect phone which has been provisioned through the FXS/DECT option (with a Gigaset N720)
    the problem is that when the users log on the 3CX client pops-up with the question which phone the user would like to use for CTI integration.
    Is it possible that the client always uses the same phone (Yealink)
    Looking forward to hearing your tips and tricks.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    5,514
    361
    Hello @Martijn
    Please note that currently there is now way to set a default phone in the 3CX client. You will be prompted every time the client starts to choose a phone to control via CTI.
  3. Martijn
    Jun 26, 2017
    5
    Thanks for the reply, will this be implemented in the (near) future?
  4. YiannisH_3CX
    May 10, 2016
    5,514
    361
    Not really in a position to know that. However you can request this by creating as a features request in the ideas section of the forum so other users can upvote this and can be evaluated by the appropriate department.
