I am not aware of a global way to do this in the 3CX PBX interface, however if the issue is that you have a lot of extensions in this system and wish to save time simply go to the "Extensions" tab in 3CX and hold down "Ctrl" and select multiple extensions and "edit".
The system supports the ability for "Block use of 3CX Client" as you have said. This can be found under Provisioning >> Access.
This option is available when in the multiple extensions selection state and should at least offer you a quick work around.
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
