3CX Cloud - Autoprovision trouble
Discussion in '3CX Phone System - General' started by millennium2, Apr 27, 2014.
  1. millennium2
    Apr 8, 2011
    55
    Just setup 3CX Cloud are having trouble autoprovision the phone with Tenant 1.
    Because we are using a Sonicwall TZ210, we disabled STUN.
    Because we have only a single public ip with many servers behind it, we had to remap ports 80 to 5050, and 443 to 9443.
    Our setup looks as follows:
    3CX Server
    192.168.15.5
    Stun Disabled
    Session Border Controller running on Workstation
    192.168.15.6
    Ports Forwarded on Sonicwall to 3CX Server for Tenant1
    5050 to 80
    9443 to 443
    4502
    4503
    5000
    5060 TCP UDP
    5061
    5090 TCP UDP
    5550
    5599
    When we call the DID, we successfully hit Extension 10's voicemail, so we know the configuration is working at the server level. Now to provisioning the phone.
    On 3CX Server, Under Extension 10, we setup Phone Provision as follows:
    MAC ID: xx:xx:xx:xx:xx (specific MacID)
    Model: Yealink T46
    Select Interface: server.company.com
    Select Provisioning Method: 3CX Session Border Control
    On the Yealink T46, we have disabled Trusted Certificates.
    Then, under AutoProvision, we enter the following:
    https://server.company.com/tenant1/provisioning/XXXXXX
    This does not work for autoprovisioning the phone.
    Given we port forward 9443 to 443, we try the following:
    https://server.company.com:9443/tenant1/provisioning/XXXXXX
    This appears to autoprovision the phone, but then upon reboot, three things are true:
    Cannot make calls
    Cannot receive calls
    On 3CX Server, phone does not appear under Phones and Extension 10 is still not registered.
    Also, even though we specifically added port 9443 to the AutoProvision URL, it is automatically removed from AutoProvision url after reboot. It changes back to: https://server.company.com/tenant1/provisioning/XXXXXX
    We have been trying to autoprovision the phone with in the LAN, so do we need to take the phone offsite (i.e. remote location)?
    Is changing port 443 to 9443 not supported?
    Is there anything else we should be doing to get this to successfully provision and register within the 3CX server panel? Any help would be greatly appreciated. Thank you.
  2. ccexpert
    Apr 9, 2014
    18
    Modify the template for that model phone to include the port number you need. The autoprovision is overwriting it when the file is downloaded the first time. Also under options of the ext you can check PBX delivers audio. That helps with STUN and ext to ext calls.
  3. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    When you reboot the phone will revert to the old template, are you making the change in the acutal file then uploading to 3cx or are are you going to the phone provisioning tab and making changes there. Based on when you said it sounds like the latter which will cause you to loose the updated config.
  4. millennium2
    Apr 8, 2011
    55
    Thank you both very much for the insightful replies.
    I went in to the 3CX Cloud server, cloned the Yealink phone template...and set the following field using Notepad ++:
    auto_provision.server.url = https://server.company.com:9443/tenant1/provisioning/XXXXXX
    That did not work, as upon reboot, the auto provision field reset itself back to the following:
    What fields to I need to edit in the Yealink template to get the phone to use different 80 and 443 ports?
    Many thanks.
  5. jpillow
    Jun 20, 2011
    1,342
    This doesnt sound like your issue is with 3cx but with your handset have you attempted to open a ticket with Yealink?
  6. bardissi
    bardissi Member
    Jan 31, 2012
    318
    Try provisioning with http instead of https
