3CX Cloud login errors
Discussion in '3CX Phone System - General' started by PMariscal, Jan 13, 2018.
  1. PMariscal
    Jan 13, 2018
    I signed up this week for the 1-year free cloud service but when I login it says "server error" or "Invalid password". I've verified the password is the same one emailed to me and tried multiple computers at different locations with multiple browsers with no luck.
    Any ideas?
  2. ADL
    ADL
    Jan 14, 2018
    I have the same issue since today... Yesterday evening it worked just fine.
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    Hello there,
    Make sure that the password you are using is correct and try logging from a different public IP address in case your IP got blacklisted. Once you log in you can remove the blacklisted IP from the "Blacklisted IPs " tab on the Dashboard
  4. PMariscal
    Jan 13, 2018
    I had this issue once before and was able to login using the way you described but it's not working anymore. Still says server error or invalid password. Password hasn't changed from the default and I've been copying and pasting.
  5. YiannisH_3CX
    May 10, 2016
    6,016
    421
    @PMariscal
    Please check your inbox as i have sent you a p.m. requesting some details regarding your installation.
  6. Ansgar
    Jan 16, 2018
    Hello, same issue here! yesterday it worked fine but today all clients are off and it is not possible to login to cloud portal - "server error".
    I try to connect from different locations with same result!
  7. YiannisH_3CX
    May 10, 2016
    6,016
    421
    Hello @Ansgar
    Are you running the free version of the PBX express or have you installed the PBX on your own instance? When you say "all clients are off" you mean that phones have disconnected as well?
  8. Ansgar
    Jan 16, 2018
    Hello Yiannis, we are using the one year trial version hosted by 3cx on the google cloud. Today the four soft clients can´t connect - the 3cx client is empty without any function.
    Log in to the admin console results in "server error". I have an external pc logged in to the admin portal yesterday - "502 bad gateway"... any idea?
  9. YiannisH_3CX
    May 10, 2016
    6,016
    421
    Please check your inbox as i have sent you a p.m. requesting a few details so we can further troubleshoot the issue
    Lalit Pandit likes this.
  10. Lalit Pandit
    Jan 17, 2018
    8
    Hello Yiannis,
    I am using one year trial version hosted by 3cx on the google cloud. Yesterday 2 clients can´t connect - the 3cx client is empty without any function.
    Pls help
  11. Lalit Pandit
    Jan 17, 2018
    8
    Can u pls help me as i'm also facing same issue...
