3CX cloud stoped after HTTPS Certificate was successfully renewed
Discussion in '3CX Phone System - General' started by Christos11, Apr 15, 2018.
  1. Christos11
    Jan 31, 2018
    3CX cloud stoped after HTTPS Certificate was successfully renewed some days after the auto update.
    Also i can't enter 3cx cloud console. "Server error" message appears
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    420
    Hello @Christos11
    Is the PBX hosted on your own instance or are you using the 3CX free 1 year hosting? If you have access to the operating system you can check if the management console is running and manually start it if it isn't.
