3CX Cloud
Discussion in '3CX Phone System - General' started by spring, Jun 13, 2017.
  1. spring
    Nov 20, 2014
    53
    Hi, i was wondering if my 3CX is on cloud and i want to connect the PSTN land line to the 3CX server instead of using sip.is it possible?
    Regards,
    Spring.
  2. Panayiotis_3CX
    Panayiotis_3CX Support Team
    Apr 26, 2017
    165
    7
    Hello @spring
    To achieve (with a supported method) a connection between the PSTN Gateway and the PBX on the cloud, you will need to create a VPN connection, as the registration messages must come from a private IP address as per RFC 1918 and not from a public IP address.
  3. spring
    Nov 20, 2014
    53
    Hi Panayiotis,
    Could you advice in a bit detail? any gateway required in this situation?
  4. tsukraw
    tsukraw New Member
    Mar 9, 2012
    191
    9
    You would create a site to site VPN tunnel.
    Then on-prem where you have your PSTN lines you would place for example a Patton SN4114 FXO gateway.
    The gateway would connect to 3CX over the VPN tunnel.
    Shoot me a PM if you need specific help. I can maybe give you a hand.
    spring likes this.
