3CX Conference Call from Windows Phone
Discussion in '3CX Phone System - General' started by Stephanie, Feb 9, 2017.
  1. Stephanie
    Feb 9, 2017
    5
    When trying to make a conference call from the desktop application for 3CX v15, it is not working with outside phone numbers. I will receive the error "Call failed - redial". I have tried it with and without the 1 in front of the phone number, but it has not worked. Any ideas of what to try or look at to fix this issue?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,380
    454
    Hello @Stephanie
    Do you have an outbound rule matching the number you are trying to dial? Can you call the same number when not in a conference call?
  3. Stephanie
    Feb 9, 2017
    5
    I am able to dial this number (and all of the other outside number that I have tried) without any issues when not using the conference feature.
  4. YiannisH_3CX
    May 10, 2016
    6,380
    454
    So while you are in a call with person A you open a second line putting A on hold and call person B. Does that work?
  5. Stephanie
    Feb 9, 2017
    5
    It works from my desk phone. If I try to create a new conference on the softphone on my PC using the conference call option, that is when it does not call the outside numbers. I need to be able to have multiple outside numbers in one conference call.
  6. YiannisH_3CX
    May 10, 2016
    6,380
    454
    Just tested on my mine and it works. Created a conference added numbers and called out. All calls went out without a problem.
    Try it the way i described above so we can see where the issue is. Call one number then put him on hold open a new line and call a second number. then press the conference button on both lines. Let us know if that works
  7. Stephanie
    Feb 9, 2017
    5
    It does work when i call 2 separate numbers on separate lines and then conference both lines.
  8. YiannisH_3CX
    May 10, 2016
    6,380
    454
    Just noticed something while trying to replicate your issue, when creating a conference the From:Display name field is populated by the conference name. Your provider might not accept this and dropping the calls. To verify this we need to see a wireshark capture but run the following test to see if that works first
    Create a conference with 2 numbers and as conference subject use your main trunk number. Then start the call and let us know if that works
  9. Stephanie
    Feb 9, 2017
    5
    I entered the main trunk number as the subject line and the call out still failed.
