Solved 3cx config file
Discussion in 'Android' started by craigreilly, Jan 23, 2017.
  1. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,947
    178
    New to v15 and user can not get 3cx to be the handler for the 3cx config file. Saves the file to downloads. Goes to download folder. Tap to open and it doesn't know how to open it.
    EDIT: Opening from FILE MANAGER instead worked just fine.
    #1 craigreilly, Jan 23, 2017
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,349
    274
    This is an issue we see with some android phones. While some associate the files automatically and open them with the 3CX client others do not and you need to use a file explorer.
    Sometimes re-installing the application works with the association
  3. finetech
    Apr 8, 2017
    I tried to open from Total Commander and it works!
