3cx Configuration for inphonex reseller
Discussion in 'iOS' started by vin.f, Dec 31, 2011.
  1. vin.f
    Dec 31, 2011
    Device Info
    Phone Model: [iPhone]
    Generation: [4s]
    Firmware Version: [5.0.1]
    Jailbreak: [NO]
    Cydia Installed: [NO]
    Issue Info
    Handset: [Phone]
    Contacts: [Local|Google]
    Connection: [WiFi]
    Server: [External*] (Unsure)
    I've just installed the 3cx app on my iphone and I'm trying to configure it to connect to a clients custom sip proxy. The sip proxy is configured correctly as I got the appropriate sip.siprealm.com pingback when executing nslookup from command prompt.
    I've had a look at his voip service providers info on configuring 3cx for iphone but the images and instructions are outdated as some of the options are not actually available. I was just wondering if there was an updated configuration tutorial for infphonex reseller accounts or custom sip proxies and if so, where can I find them as I need to test if everything is working correctly.
    If not, I would really appreciate it if someone could explain the config to me and what info I need add to set this up correctly.
    Thanks in advance for any help.
    -Vin
  2. StefanW
    Jun 2, 2009
    1,199
    79
    the 3CX phone is desinged and tested to work with 3CX Phones Systems.
    We do not make tests to other Providers or PBX Systems but may work if they work as by RFC standards.
    If the service is located external:
    User
    ID
    Pass
    Out off Office - ON
    External Server
    Proxy (Optional)
    Stun (Optional when using proxy)
    The a check via Wireshark is a must to be if not used with 3CX.
    If you would use 3CX the hole config setup is run out of the box from the PBX via auto provisioning
