3CX configuration for VoiceStick
Discussion in '3CX Phone System - General' started by Halea, Nov 4, 2008.
  1. Halea
    Halea New Member
    Jan 5, 2008
    151
    Greets:
    Does anyone have the confirguration parameters to make 3CX work with VoiceStick?
    I can get 3CX to register with VoiceStick and receive calls; everything works well in that direction.
    But when 3CX makes a call out over VoiceStick I get an error message indicating that there is a timeout/no answer problem. The message is as follows:
    21:42:03.186 Call::Terminate [CM503008]: Call(42): Call is terminated
    21:42:03.006 Call::RouteFailed [CM503014]: Call(42): Attempt to reach [sip:18005551212@192.168.0.100] failed. Reason: No Answer
    21:42:02.996 CallLeg::eek:nFailure [CM503003]: Call(42): Call to sip:18005551212@i2telecom.com:5060 has failed; Cause: 408 Request Timeout; internal
    21:41:30.469 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(42): Calling: VoIPline:10004@[Dev:sip:17077472525@i2telecom.com:5060]
    21:41:30.419 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:18005551212@192.168.0.100]
    21:41:30.399 Extension::printEndpointInfo [CM505001]: Ext.222: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA3102-5.1.7(GW)] Transport: [sip:192.168.0.100:5060]
    21:41:30.279 CallCtrl::eek:nIncomingCall [CM503001]: Call(42): Incoming call from Ext.222 to [sip:18005551212@192.168.0.100]
    If anyone can help it will be greatly appreciated.
    Halea
