3cx configuration problem for Raspberry pi 3
Discussion in '3CX Phone System - General' started by perdicaro, Jan 21, 2017.
  1. perdicaro
    Jun 1, 2013
    26
    I successfully installed on my raspberry 3cx and properly configured ports 5000 and 5001 and opened its doors on 80 5000 5001 router, 3CX is running properly but when I enter my ip address (http: // myip: 5000) does not connect ; how can I do?
  2. Trever
    Jan 17, 2017
    5
  3. Sopock
    Sopock Member
    Jul 11, 2012
    448
    20
    So it's almost possible after all? Not only SBC?o_O
  4. perdicaro
    Jun 1, 2013
    26
    I tried everything, both 5000 and 5001 as well 80 nothing works;It may be the new os raspbian pixels that is not compatible?
  5. Sopock
    Sopock Member
    Jul 11, 2012
    448
    20
    nginx?:confused:
    The PBX configuration tool obtains important network and security settings and configures 3CX accordingly. To run it, enter the IP followed by port 5015
    Code:
    sudo apt-get install nginx
    By default, NGINX puts a test HTML file in the web folder. This default web page is served when you browse to http://localhost/ on the Pi itself, or http://192.168.1.10 (whatever the Pi's IP address is) from another computer on the network.
    #5 Sopock, Jan 21, 2017
  6. perdicaro
    Jun 1, 2013
    26
    I followed this official guide http://www.3cx.com/docs/3cx-sbc-raspberry-pi/ and the advice that you gave me, but I always have this connection error with port 5015 5000 5001 5060 5090, impossible to connect at the 3cx consol
    i try whit public ip and also whit internal ip in my case 192.168.1.6
    ERR_CONNECTION_REFUSED (crhome browser)
    CAN'T CONNECT TO SERVER (safari browser)
    whit port 80 i have this message now
    Welcome to nginx on Debian!
  7. perdicaro
    Jun 1, 2013
    26
    my 3cx conf 3cxsbc.conf
    Code:
    [General]
    ReconnectInterval = 30 # seconds
    PrintStatsInterval = 30 # seconds
    FailoverInterval = 90 # seconds
    [Log]
    Type = file     # cout, cerr, file, syslog
    Level = ERR     # NONE", "EMERG", "ALERT", "CRIT", "ERR", "WARNING", "NOTICE", "INFO", "DEBUG", "STACK", "CERR", "$
    # File = "/var/log/3cxsbc.log"
    [Bridge/123456]
    #Mandatory
    ID = 123456
    Password = password
    TunnelAddr =myexternalip                    # 3CX Phone System Tunnel TCP IP or FQDN
    TunnelPort = 5015               # 3CX Phone System Tunnel Port
    #TunnelAddr2 =                  # 3CX Phone System Failover Passive Tunnel IP or FQDN
    #TunnelPort2 =                  # 3CX Phone System Failover Passive Tunnel Port
    #Optional
    Name = "3CX edi"
    PbxSipIP =myexternalip                      # IP address of PBX, mandatory for provisioning to work
    PbxSipPort =5016               # SIP port of PBX, mandatory for provisioning to work
    #LocalSipAddr = 192.168.1.6         # local SIP (UDP/TCP) address (def: 0.0.0.0) binds on all interfaces
    #LocalSipPort = 5015            # local SIP (UDP/TCP) address (def: 5060) Must be 5060
    SecurityMode = 0
  8. perdicaro
    Jun 1, 2013
    26
    I try to install 3cx on my notebook macchine and working well, the problem still only whit rasperry
  9. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,956
    180
  10. perdicaro
    Jun 1, 2013
    26
  11. GiannosC_3CX
    GiannosC_3CX Guest
    Hi there,
    The Linux 3CX Phone System works only on Debian 8 and not on different Linux distributions or on Raspberry PI.
    On Raspberry PI you can install the 3CX Session Border Controller (SBC).
  12. perdicaro
    Jun 1, 2013
    26
    Thank you, finally a clear answer :)
  13. the136
    Nov 16, 2016
    7
    Is there a reason there is so limited support for Linux? Debian 8 and nothing else is such a restrictive solution, it makes little sense?
    Does anyone know if there are any plans to license the code? At least then I can build the software on any system I choose.
  14. Sopock
    Sopock Member
    Jul 11, 2012
    448
    20
    Maybe they could use universal Linux packages?:confused:
    Developers can release stable, candidate, beta and edge versions of a snap, at the same time, to engage with a community who are willing to test upcoming changes. You decide how close to the leading edge you want to be.
    https://github.com/dotnet/core/issues/447
  15. Umbrella
    Sep 16, 2017
    13
    can anyone provide more info on how stable are the raspberry pi's in a production env ?
    i'm wondering if a lenovo tiny with ssd will be a better fit. my main concern is uptime and recovery.
    searching online, people are reporting 3 months up time at best.
    #15 Umbrella, Sep 20, 2017
