3cx connected to 2 offices
Discussion in '3CX Phone System - General' started by joostehost, Jul 30, 2012.
  1. joostehost
    Jul 30, 2012
    I have two offices, in one of them I have a 3cx server. In that office we have 2 Yealink phones.
    Now I want to connect this office to a remote office over the internet.
    That office will use 2 soft phones at first.
    I would just like to know how I can connect these two offices so they both use the server in the first office?
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,088
    65
    Look at the blog for remote extensions as this will give you the instructions on how to remote phones. You may also need to consider using the SIP proxy manager (again look on the blog for this) as it may help to overcome an firewall issues.
  3. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    You can setup the SIP Proxy manager at the remote location and that will handle those remote exetnsions, or you can setup two remote extensions using 3cx tunnel. Both can be found in 3CX Blog just search remote extension. I've usually just set up remote extensions using the 3cx tunnel or even setup the remote user with a VPN.
