3CX Connection test - for remote users / phones
Discussion in 'Ideas' started by r.towle, May 24, 2016.
  1. r.towle
    Apr 11, 2013
    67
    10
    Is there a utility that can test / troubleshoot 3CX tunnels / remote connections when outside of the office / no admin access to the PBX?
    I'm thinking as a remote user for them to be able to run a utility which tests the ports and communication with the PBX and gives some sort of useful output for the user to forward on to the PBX admin to investigate why there may be connections problems.
  2. r.towle
    Apr 11, 2013
    67
    10
